Model: V5
Refrigerant Type: CFC-12
Ambient Temp: 100
Pressure Low: 27-35
Pressure High: 210-275
Country of Origin: Japan
Ambient is 100F 25% RH. Mid afternoon sun.
~750RPM idle. Transmission in D.
35psi L; 210 psi H. recirc
The needle flutters on high side by a small amount, but very rapidly. I can actually hear the high side gauge buzzing.
1500RPM
27psi / 240psi
45F vent output on recirc windows shut
1500RPM fresh air with windows down
35psi 275psi
Compressor is a variable displacement type that attempts to maintain a constant low pressure.
Fan setting was on highest in every test.
Edited: Fri August 17, 2012 at 9:39 PM by Leggie
