Durango ac problems
bigkev on Mon August 06, 2012 2:22 AM User is offline
Year: 2003
Make: dodge
Model: durango
Engine Size: 4.7
Refrigerant Type: r134
Ambient Temp: 70
Pressure Low: 100
Pressure High: 125
A Durango im working on had no ac when I first looked at it. I checked the pressures and noticed that both sides was almost the same pressure with the compressor running. I figured the expansion valve must be bad on it. I put a new expansion valve on it, vacuumed, and refilled. Now the pressure is about the same but it seems like I get some cool air out the back vents and almost none out of the front vents. The compressor is not making any weird noise nor has it. I wonder if its possible I was sold the one for the durango without rear ac, Ill check that in the morning. I noticed on some auto parts websites they list a front and a rear expansion valve. Has anybody replaced the rear valve or know where it is?
bigkev on Mon August 06, 2012 2:43 AM User is offline
After looking online it seems that it does have a rear ac expansion valve. It would make complete sense for the back one to be stuck open causing the front to not get cool at all and the back to get a little cool. Does anybody know where the expansion valve is located for the rear unit? I guess if nobody knows ill start following lines tomorrow.
bohica2xo on Mon August 06, 2012 11:44 AM User is offline
Kev:
Run the engine speed up to 2500 rpm & see what you have for pressures. That vehicle should have an SD7 compressor, which will pump enough volume at that speed to over run a wide open TXV
If you have the same pressures at 2500, then the compressor is toast.
B
Edited: Mon August 06, 2012 at 11:46 AM by bohica2xo
GM Tech on Mon August 06, 2012 12:25 PM User is offline
rear expansion valve is at the entrance to rear evaporator- under all the plastic covers
bigkev on Wed August 08, 2012 1:47 AM User is offline
How much should it overrun? I did rev it a few times when checking pressure and it did slightly increase. Also ty gm tech for location.
bohica2xo on Wed August 08, 2012 2:36 PM User is offline
Kev:
With a full charge it should be able to provide cooling to both expansion devices @ full load. You should have seen less than 50 psi on the low side & closer to 180 on the high side if it was pumping.
Looks like a reed valve failure. Just not pumping much. A badly worn compressor with working reeds will produce cooling at higher speeds.
B.
ice-n-tropics on Wed August 08, 2012 9:06 PM User is offline
FYI,
Durango had a 33% warranty on compressors which was caused by the ETN rear expansion valve which had the metering pin off center. The counter measure was a Japanese TXV.
hotrodac
bigkev on Fri August 17, 2012 2:28 AM User is offline
compressor wont overrun itself much at all so I guess it must be toast as you guys said. Im going to put a compressor on in the next couple days and I'll let you all know how it goes.
NickD on Fri August 17, 2012 7:56 AM User is offline
Is the expansion valve the culprit or the victim? More than likely the victim, but flip a coin. Recall a recall sometime in this era on poor evaporators, did you check the surfaces for oil leakage?
Note my local library has quite a selection of DIY repair books, most state you are looking for a single problem, an idiot writing a book for idiots. An AC is a system with a chain reaction characteristic. Have to evaluate the entire system and judge whether repairs are feasible or not.
Had a conversation with my son last night about his 2002 T&C with 96K on it with numerous problems, AC was only one of them. Book value was $1,700, repair cost having it done was $4,700, but then would soon experience head gasket problems. Just get rid of it, that is what he did. Major problems was in the transaxle followed by ten years of driving in road salt, so not only evaluate the systems, but the entire vehicle as well. He managed to get buy with 18 cents per mile depreciation, really not that bad in this day with all throwaway stuff.
For us hard working people, nothing could have been worse for us than that crazy clunker program, a whole new ballgame now, leaving most of us in left field if even in the ballpark.
bigkev on Thu September 13, 2012 12:31 AM User is offline
Thanks guys, sorry it took so long to get back, compressor did the trick cools like a new one. Old compressor had no abnormal noises and felt good when I turned it, no shavings anywhere either. Thing must have a busted reed inside it, maybe ill get bored and tear it apart just for fun. Thanks again!
Edited: Thu September 13, 2012 at 12:32 AM by bigkev
