Farily new a/c stops blowing cold air after 10 minutes
hekg on Wed July 25, 2012 9:27 PM User is offline
Year: 1999
Make: Chevy
Model: Tahoe
Engine Size: 5.7
Ambient Temp: 96
Hi all,
My Chevy Tahoe's a/c system stops working after about 10 minutes of working great. The compressor is a fairly new delco which is less than a year old and was installed by a professional.
Once it works for a while and i guess overheats then it stops working. I turn the a/c off and turn it back on and I can hear the compressor engage and disengage immediately.
Please help me .. thank you!
Cussboy on Wed July 25, 2012 9:44 PM User is offline
Check your fan clutch/cooling fans. Sounds like the condenser isn't able to shed enough heat.
Spray water on the condenser; if that helps, your fan isn't cooling the condenser enough.
