Model: Focus
Country of Origin: Mexico
The car is designed in such a way that high side port is accessible right on top of the condenser, but the low side port is hidden behind the wheel well.
I know that refrigerant migrate from hot to cold. Is it ok to use heated cylinder or a recovery machine to push the entire charge into the system by the high side port so that wheel well won't have to be removed?
If you have the proper equipment you can "fill" a system through the high.
That is the method used at the assembly plant-- that is why you'll always notice that high side ports are always easily accesible on any vehicle-- for factory fill.
