1998 Mustang AC will not turn on
Mustang1 on Sun July 01, 2012 6:24 PM User is offline
Year: 1998
Make: Ford
Model: Mustang
Engine Size: 3.8L V6
Refrigerant Type: R134
Ambient Temp: 95
Pressure Low: 110
Pressure High: 110
1998 ford mustang V6 will not turn on
FS10 compressor
Low side pressure static 110 psig/about same when engine running
High side pressure static 110/about same when engine running
Above checked separately with gauge set to verify no leaks in gauge block
Compressor clutch will cycle when jumpered to battery
Compressor did not cycle when low pressure switch jumpered with system running
Replaced low and high pressure pressure switches (no change)
Aux fan does run when ac switched on
Compressor turns by hand
Any thoughts on what to test/try next to diagnose problem? Thanks
Dougflas on Sun July 01, 2012 7:11 PM User is offline
Does the 98 have a CRM module like the 95 models?
Mustang1 on Tue July 03, 2012 10:37 AM User is offline
Mustang1 on Tue July 03, 2012 10:38 AM User is offline
Ye, I believe it does.
Dougflas on Tue July 03, 2012 11:44 AM User is offline
That is a good place to start
Mustang1 on Wed July 04, 2012 1:33 PM User is offline
Thanks, any recommended test method?
Dougflas on Wed July 04, 2012 4:16 PM User is offline
Do you have the schematic? If not, you can get a vehicle specific CD with all info for your car.
Mustang1 on Thu July 05, 2012 6:52 PM User is offline
Control module was bad. Swapped it, works like a champ. Thanks for the help!
