Year: 2000
Make: Buick
Model: CENTURY
Engine Size: 3.1
Refrigerant Type: R-134a
With ( V-5 ) belly leakier is it pulling air in when it is leaking at the case O-rings ? or just leaking R-134a out ?
Life is not measured by the number of breaths we take - but by the moments that take our breath away
Thanks, Randy
IF the system has a charge and the static pressure and operating pressures are above atmosphere, it is only leaking refrigerant. IF the charge is lost or the low side drops below atmosphere (14.7 PSI), and IF the belly o-ring is directly in the low side circuit; it will then "suck" air.
Thanks ! Hecat
Thanks, Randy
