Year: 1997
Make: Chev
Model: Suburban
Engine Size: 5.7
Ambient Temp: 86
Pressure Low: 36
Pressure High: 360
The A/C system has worked OK as long as the outside temps are below 85 degrees. Lately I've noticed that sometimes when I start the A/C system that air will be hot at the beginning and then begin to cool after 5 minustes or so. I mangaed to pull over when this happened recently and found the clutch disengaged and then suddenly engage. I measured the clutch gap to be .016. Are these models prone to have relay failures??? I have evacuated the system several times over the last few years and add 64 oz of R134a for a dual system. It does seem to cool better on the road than in stop and go traffic. The condensor is clean. Does it need a pusher fan???? Also, what is the correct orifice tube??White..or white and yellow???? thanks Arne
Sounds like a bum fan clutch and you have high pressure cut-outs---how much air is crossing the condenser at idle? spray it with water see if it cools better- and check the air flow behind the cooling fan...
the fan Clutch has been replaced.
I have cleaned the condenser and the faster you drive the cooler it gets up to 85 degrees. Are the pressures OK???
360 head pressure is way too high about 100 psi too high-- did you pull a vacuum prior to charging? could be air in the system...
I did pull a vacuum for about 75 minutes and added using an electronic scale 64 ozs. Could the system have too much oil????
Mist water on condenser from a garden hose and report back discharge pressure...
Wife took the truck to visit the daughter for a week. Will mist condenser next week. Question: With an ambient of 86 degrees and a low side of 36 and a high side of 360...would that indicate an overcharge of oil or possibly the wrong orifice sized tube???
Indicates an air flow over condenser issue-- or a partially plugged orifice... oil doesn't cause high head unless it is completely full of oil....saw a C/K truck once with 48 ounces of oil in it.....
It certainly doesn't have 48 oz of oil. I had flushed the system several years ago when the compressor failed. I did install an aftermarket condenser but have an OEM GM ready to install when I need to. I am not sure as to the OT. It is either going to be yellow or white. If it had the white OT...would that cause r high pressures nd..Does the higher pressure prevent the system from cooling when the temps go above 90 degrees????
