Year: 1986
Make: Toyota
Model: 4Runner
Engine Size: 2.4
Refrigerant Type: 134
This started out as a retrofit but after poor performance, even with a rebuilt compressor, I've decided to replace/renew the entire system. what I need to know is how to hook up the drier, one port of the drier has "in" written on it, which line connects up to the in port? I'm replacing the condenser, evaporator, expansion valve and drier as well as all the Orings, as i said the compressor has been rebuilt. Also what type of oil should I use, I started with PAG 100, is this the correct oil?
Thanks in advance,
Corey
In side from the condenser.
Cool, thanks!
