More blower problems
ldj1002 on Fri June 22, 2012 11:42 AM User is offline
Year: 2002
Make: Ford
Model: Crown Victoria
A few weeks ago blower went out. I got help here on the forum. I replaced blower motor, still wouldn't blow. I them replaced resistor and it worked perfect, Now 3 days later blower wouldn't come on. When I rotate the blower speed control all way up to it will come on. When I try to lower blower speed it won't, only runs on high. What now?
GM Tech on Fri June 22, 2012 12:13 PM User is offline
Blower motor relay is inop or bad connections
ldj1002 on Fri June 22, 2012 2:38 PM User is offline
Where is that relay?
mk378 on Fri June 22, 2012 5:42 PM User is offline
Resistor could have burnt out. Pull resistor and inspect. Also check the resistor plug for any melting / burning. A mouse nest in the ductwork will impede airflow to the resistor.
