Adjustable low press cycle switch
Turbo on Sun June 10, 2012 7:03 PM User is offline
Year: 1999
Make: jeep
Model: Grand Cherokee
Engine Size: 4.7
Hello, I would like to know if there is an adjustable low pressure cycle switch I can use in a 1999 jeep grand Cherokee. The factory switch is not adjustable. Is there one I can use which will screw right in and possibly have the same wiring connector. It does not have to have the same wiring connector, I don't mind cutting and splicing. Or maybe a way to change the set point on the factory switch?
chris142 on Sun June 10, 2012 11:49 PM User is offline
I couldn't find one for my 02 Wrangler. First is your going to have to use a different connector. Some GM cars have a switch thats adjustable and has the correct threads but it would hit the pipe on my Accumulator and would not fit.
