Tim- do you sell a/c caps by the bag?
GM Tech on Fri June 08, 2012 6:44 AM User is offline
Seems I always need caps- most common issue- cars come to me misisng high and low side caps-- saw high side cap on ebay-- but for $12 a cap -- wth? So here's your chance to win one!
NickD on Fri June 08, 2012 6:52 AM User is offline
See if you can get some good old fashion metal ones with a good neoprene seal.
Second group that should be shot with these cheapa$$ plastic ones.
GM Tech on Fri June 08, 2012 6:59 AM User is offline
Never seen a metal cap for 134a --- metal caps as I knew them where for pre-1993 model cars-- NickD- you seem to be living about 20 years behind the times LOL!
Metal Man on Fri June 08, 2012 8:03 AM User is offline
GM TECH, If you cant find any let me know. I work at a salvage yard. I'll could send you a hand full if you want. They will be used,but free.
TRB on Fri June 08, 2012 9:15 AM User is offlineView users profile
Bottom of this page has the R134a caps. We also should have some R12 caps at the office.
http://www.ackits.com/c/Miscellaneous/Miscellaneous+Products.html
buickwagon on Fri June 08, 2012 9:49 AM User is offline
Oddly enough, while the outside dimensions of the R134a service ports are standardized, the inside thread dimensions are not. As near as I have been able to determine, there are 5 different sizes:
High side:
M10 x 1.25
M10 x .75
M8 x 1
Low side:
M8 x 1
M9 x 1
So you can't just get a bag of low-side caps and a bag of high-side caps and be sure of fitting all vehicles. FWIW both my GMs used 8mm threads on both high and low pressure ports. I found them for about 60¢ each or $35 for a bag of 100. $12 per cap seems just a little bit steep.
I've saved hundreds on service by spending thousands on tools.
NickD on Fri June 08, 2012 12:39 PM User is offline
More like in a time when people had common sense and more interested in conserving refrigerant than losing it due to a cheapass plastic cap that gets brittle and breaks in half.
Even remember you saying the cap is the only good seal.
Don't know why I didn't think of this before, thread sizes are common enough, have a machine tool lathe, maybe I will make my own. And since I am an idiot and can't tell the high from the low side, will put a dab of green or red paint on the top.
buickwagon on Fri June 08, 2012 5:46 PM User is offline
Well this could prove interesting. I too have a lathe and will love to see how you accomplish this. I think it would have to be two-piece, since the cap surrounds the male thread. However, I suppose if you ground a tiny threading tool, similar to an internal threading tool in that you would feed from the end instead of the side but oriented to cut a male thread, you might sneak it between the shroud and the threaded portion.
If you tackle this, please let me know how you made out. Preferably with pictures!
chris142 on Sun June 17, 2012 11:12 AM User is offline
Ya I'm always getting a Ford in and it's missing it's high side cap. The Ford ones are different than most others. Another one I have a hard time finding are the smaller r12 caps.
buickwagon on Mon June 18, 2012 10:57 AM User is offline
I just noticed that you list an M10x1 high side cap. Is that a misprint or is there a sixth size out there too that I didn't know about?
TRB on Mon June 18, 2012 11:25 AM User is offlineView users profile
We have available a complete R12 & R134a Cap Kit. Runs about $19.00. Working on getting some images for you all.
