Year: 2001
Make: Chevy
Model: Tahoe
Engine Size: 5.3
Ambient Temp: 80
Pressure Low: 42
Pressure High: 205
I just replaced the compressor, accumulator, o-tube, & rear TXV, & these are the gauge readings that I ended up with after I charged the system. It was late at night; so although the ambient temp was only 80, humidity was 83%. It felt rather hot. I used exactly 11 oz of PAG 46 & 48 oz of refrigerant. All parts are Delphi except for the rear TXV, which is aftermarket. I pulled a 30 min vacuum, & I let it sit under vacuum for 30 min. It pulled down to 30 in Hg. I flushed the system very thoroughly. I went through over 2 gallons of flush, & I ran a lot of air through each heat exchanger after flushing in order to remove all solvent.
Despite all this, I ended up with a rather disappointing vent temp of 53F, & the rear A/C had a vent temp of 58F. These readings were with both fans on high & with the system in recirculating mode. Driving the car around, the vent temp came down to about 48. Driving the car the next day with the ambient in the low 90's, vent temps were higher than I thought they should be, & there was a very large difference between vent temps at idle & vent temps while under way. Sitting at idle, vent temps were 68, driving at surface street pace, they came down to 58, & at a freeway pace, they came down to 49. These temps were all with the fan speed on its middle setting, the system in recirculating mode, & full cold temp setting. The rear A/C was also on, & its setting were the same.
I did a complete system replacement on a 95 Suburban that I used to own a few years back. The end results were similarly disappointing, & on that car, I also replaced the condenser. In both cases, although I never measured vent temps pre-repair, I could tell subjectively that both performed better prior to their failures than they did post-repair. In fact, the results on the Suburban were even worse than this Tahoe, but I don't remember the numbers. Clearly, I'm doing something wrong, but I can't figure out what it could be.
On the Tahoe, I don't think I have a blend door problem. I ran the blower with the compressor turned off, & the vent temps were equal to ambient. Also, recirculating mode is working properly.
Any input and/or diagnostic techniques to help me nail this down would be greatly appreciated.
Michael Keith
Vintage Car Solutions
Houston, TX
BTW, I forgot to mention that the fan clutch is about a year old, & it is in good working order. I can hear it loud & clear when I drive away after idling the car for a while.
Michael Keith
Houston, TX
Did you try to clamp off the heater hoses?
I didn't clamp off the heater hoses, but I could. I thought that running the blower with the compressor switched off proved out that issue since I got an air temp equal to ambient when I did that with the motor at hot idle. I figured that if I had an issue with air getting to the heater core, I'd have gotten slightly heated air from the vents when I did that.
Michael Keith
Houston, TX
It IS a Tahoe..they aren't known for the best cooling systems.....
The important thing is- are you happy inside? While driving do you have the urge to open the windows to be able to breathe? Does your wife complain about it? Put the thermometer away and make your decisions. You will pull the rest of your hair out otherwise.
Highly possible- that's why I don't flush with solvents-- I use refrigerant...
What kind of flush did you use? How long did you "Blow" for drying? How long did you vacuum the system?
Johnsen's A/C flush with a Mastercool flush gun. I blew air through each heat exchanger multiple times in both directions; probably a total of about 3 to 5 minutes of air per exchanger. No visible flush vapor once I was done, but the return air still smelled slightly of flush solvent. I liked the flush gun on your web site. Do you sell direct, or only through your distributors?
GM Tech- Refrigerant flushing sounds interesting. Any way I could find someone in the Houston area that does that?
Michael Keith
Houston, TX
All GM Dealerships are required to use their recovery machines to flush with-- they have all been supplied with flushing kits-- whether they use them is up to them.
Refrigerant Flushing machines work very well.
Hecat H1000
Johnsens makes more than one flush and I could comment more about the chemistry if I had the specific one you used. Regardless we have found that a minimum of 20-30 minute blow time is needed to remove the solvents that will evaporate, and the ones that don't should never be put in their in the first place. Based upon your blow time I do agree this may be a big contributing factor to your system operating problems. I would also be concerned about the condition of your vacuum pump oil (solvent contaminated) and its ability to pull good vacuum.
Solvent flushing can and is done correctly every day. But unfortunately, when done incorrectly it causes more problems than it resolves.
Any and all HECAT flushing products are available from this site's sponsor.
I haven't had time to do anything about this, but recently, it began making a strange noise from the rear A/C lines. I decided that this latest issue should have its own post; so here it is: http://www.autoacforum.com/messageview.cfm?catid=2&threadid=23687
System performance is unchanged from when I first posted about it.
Michael Keith
Houston, TX
