Year: 2009
Make: Chevrolet
Model: Aveo
Engine Size: 1.6L
Refrigerant Type: R-134a
Ambient Temp: 90
Pressure Low: 80
Pressure High: 150
Country of Origin: Korea, Republic of
Where can I find the refrigerant control valve aka RCV aka pressure control valve for the V-5 compressor on this car. The dealer says it is part of the compressor. I have found one company in China that sells the seven different versions of the valve with different set pressures. They are said to fit all years and work with a Daewoo which it what the Aveo really is. Shipping from China is close to $40 and although they say they are ISO9000 certified there always the specter of chinese junk. Is there another source for this valve?
We carry many of the different control valves. Just need to know the color.
http://www.ackits.com/merchant.mvc?Screen=CTGY&Store_Code=01&Category_Code=CompressorControlValves
The compressor is a Delphi V-5- not a Dawoo-- I would not count on them crossing over---BTW why do you think it is bad? Just curious, I see about 1 bad one every five years.
The number one diagnostic aid--How much refrigerant did you recover? You may have a big leak...
Responses 2,3,4 are no big deal---on a V-5 - at no stroke, there is little resistance. and it will run as long as there is at least 4 oz (40 psi) in the system
That 80 psi suction may not be true-- be careful- prove to yourself it is real- 80 psi just happens to be a static reading as well-- so your gage may not be communicating with your system-- your port may not be opening with valve depressor...
80 suction psi and 150 discharge are rare combinations-- I would expect a failed control valve to be more like 80 and 90--- so it is stroking somewhat to get that 150.
pull the charge and weigh it as your first step if you haven't already.
I just don't see very many control valve failures.....
Installed new refirgerant control valve this weekend and all is well. 40 psig low side and 200 psig high side.
