Jeep Clutch Replacement...
jesaire on Tue May 29, 2012 11:00 PM User is offline
Year: 1999
Make: Jeep
Model: Wrangler
Engine Size: 4cyl.
Senior members..
I have a jeep wrangler that appears to have a bad a/c clutch, it reads .3 ohms between hot and ground of the clutch assembly, I do not pick up any resistance to chassis ground.....could you lead me to a manufactured website that might list the ohms values on a clutch.
My next question is can I just replace the clutch assembly or am I looking at an entire compressor assembly?
Jesaire,ca
TRB on Wed May 30, 2012 1:01 AM User is offlineView users profile
If you can find one clutch assembly will be close to $125.00. You can get an entire new compressor for $225.00.
GM Tech on Wed May 30, 2012 6:43 AM User is offline
Or you can do what I do-- take your DVM with you to your favorite bone yard-- ask them to see their core pile of compressors-- those that come back as trade-ins for good used stock-- then find your model, then test the coil right there-- then offer them the $30 core charge for the entire compressor-- then go home and remove the coil and install it on your vehicle- without even discharging the system! That way you meerly bought a good used coil- and saved yourself a lot of hassle....
