Year: 1967
Make: Chev
Model: Corvette
Engine Size: 327
Refrigerant Type: R-12
Ambient Temp: 90
Pressure Low: -15" hg
Pressure High: 150
This winter I decided to rebuild the R-12 AC system in my 67 small block car. I did the following to the car.
1. Replaced the shaft seal in the compressor.
2. Had the filter Dryer rebuilt.
3. Replaced the incorrect expansion valve with the correct J clamp style bulb (purchased from Corvette Central).
4. Bench tested the POA valve. Relieved at 32 PSIG.
5. New hoses and clamps.
6. Added 10 oz of new refrigerant oil.
Triple evacuated entire system and pulled the system down to 250 microns and pressure did not rise above 500 microns after 12 hours.
Using a dial-a-charge I transferred just over 3 lbs of R-12 with the compressor in operation. Blower fan was in the high position.
The ambient temperature was 90 degrees F
After 5 minutes of operation the head pressure was 150 lbs and the suction pressure was 15 inches of hg. The suction pressure did rise to 0 psig once during the test and then returned to approximately 10" hg before I shut the system down.
The sight glass is free of bubbles.
It almost appears that the new expansion valve is malfunctioning and simulating a pumped down condition.
I do not have a refrigerant recovery device and I just added my last three pounds of R12 so I am very interested in suggestions from this forum that first address corrective action that does not include opening up the system initially.
Thanks----Mark
I'd be tapping the snot out of that TXV-while it is running- it appears to be stuck- since you are running in a vacuum-- could it be POA stuck as well? I'd tap on it too.-- with a ball peen whammer.
GM Tech
I followed your advice using the hammer on the expansion valve. I also placed the thermal bulb in boiling water and then into an ice bath for a couple of cycles. Still did not work.
Time to open up the system
Mark
Remove the TXV. See if you can blow thru it while holding the bulb in your hand. Then put bulb in ice. It should shut down.
A good TXV installed backwards will slam shut like that too.
If it's not a complete blockage, the restricted part (which is normally on the high side and thus should be warm) will get cold.
I removed the new expansion valve and it is stuck in the closed position. I even put the thermal bulb in boiling water and was still unable to blow through the valve body. The new valve is out of warranty so it looks like I will have to purchase another new valve.
Thanks for your suggestions---Mark
Sounds like you lost the charge in the sensing bulb.
