Year: 99
Make: Lexus
Model: 300
Refrigerant Type: 134???
Ambient Temp: 12ðC(54ð
Pressure Low: 70
Pressure High: N/A
My buddy recently purchased this car. Just for fun, we hooked up the gauges -- well, one gauge, we couldn't find a high pressure port anywhere. With the engine off and cool, ambient air temperature of 12ðC (54ðF) & R134a connectors, the static pressure was 70psi. At that temperature, I would have expected a pressure of ~50psi, right?
Is this an indication that it's not 134a inside those pipes? Looking at various charts, I'm thinking maybe someone put R-22 in. What would the effect be of using R-22 in an automotive system? (I mean noticeable symptoms -- I already know it may cause corrosion and component failure due to excessive high side pressure)
BTW: when running it cycled between 20 and 43 psi.
I've saved hundreds on service by spending thousands on tools.
Could be contaminated with air (didn't evacuate before charging). R-22 won't work at all in an auto system, the TXV isn't calibrated for it.
I don't think it has a TXV. The compressor was cycling and I didn't see a valve or bulb. It did get cool.
