Local pawn shops have quite a few Tek-Mate 705-202 leak detectors 'in stock', of course they know nothing about them, but the prices are under $100. The brand has a good reputation and I'm wondering what to look for when buying one used? I'm a diy'r and I want to add this tool to the arsenal. I've seen then as low as $10. The sensor is replaceable, so is it an expensive replacement item? Thanks.
At 2, I went home with a 10. At 10 I woke up with a 2 !!
The sensor seems to be about a $50.00 part. If the unit powers up, beeps, and the pump runs, it seems a safe bet that that most that could be wrong is the sensor. They should respond to "duster" gas (make sure it is diflouroethane, or 1,1,1,2 tetraflouroethane (aka R-134a)-- some duster cans are filled with HC) if you are allowed to test it before buying.
Edited: Tue March 06, 2012 at 12:47 PM by mk378
ok thanks for the help. I appreciate it.
Dave
It's just a little plug of foam, should be able to fabricate one out of a lawnmower air filter or something. It's just there to keep lots of liquid or dust from going up the tube.
