Year: 1998
Make: Range Rover
Model: p38
Engine Size: 2500cc
Country of Origin: Sri Lanka
Finally I have to replace the compressor after a o-ring job done about 3 months ago.
From the breakers yard found a DENSO 10PA17C from a TOYOTA HIACE , but it's suction/discharge manifold is different.
Can I interchange manifolds?
the compressor no's are;
existing one ; 447200 - 3212
toyota one ; 447200- 5432
thanks & regds
Hmmmmmmmm... nobody?
May be my qstn is not clear. I'm talking about the square plate on top of the compressor where u connect the suction/ discharge hoses.
regds
You can search "docs blocks" and look for the compressor block you may need; or you can return to the donor vehicle for the OE blocks which may require some fabrication to adapt to your vehicle.
