part problem wassup with this (pics)
cthamalis on Mon November 07, 2011 3:31 PM User is offlineView users profile
Year: 1992
Make: Lexus
Model: SC300
Engine Size: 3.0L
Refrigerant Type: 12
Ambient Temp: 50
Pressure Low: 40
Pressure High: ?
Great forum. learned a lot here.
came across a slight hiccup in the parts supply, wondering if anyone else has seen .
old Rcvr/dryer below note the index hole positions
New one (again index holes)
Hmmmm.... Now what
Advance and autozone napa all have the same "" new "" one, lol ( but i did check)
Thanks for looking
Edited: Mon November 07, 2011 at 3:34 PM by cthamalis
TRB on Mon November 07, 2011 3:35 PM User is offlineView users profile
Contact the supplier and see if they can get you the correct one.
cthamalis on Mon November 07, 2011 3:39 PM User is offlineView users profile
well that was fast hadn't even finished editing it !!
tim I did note your website listed a different part number wondering if some one could pull it and compare the pic ( old one ) lol and i'll get it right now over night if it's the right one !! thanks
TRB on Mon November 07, 2011 3:56 PM User is offlineView users profile
37-13907 seems to match up.
cthamalis on Mon November 07, 2011 4:14 PM User is offlineView users profile
well I went to place the order on the website.....
Hmmm 84.00 in shipping for a 1 lb / 11.00 part overnight is a little steep....
guess i'll keep looking
30 in shipping i woulda done, but not 84
or would it be better to phone your office to finish this up ?
thanks
TRB on Mon November 07, 2011 4:23 PM User is offlineView users profile
It's UPS rates not ours. Ground will be a lot less.
Call Rob will your ZIP code and he will double check the rates.
Edited: Mon November 07, 2011 at 4:24 PM by TRB
cthamalis on Mon November 07, 2011 4:30 PM User is offlineView users profile
And , I don't mean to sound like I'm B%&$*#*@!*ching either it's just .... well, you know.
thanks
JACK ADAMS on Mon November 07, 2011 6:12 PM User is offline
Well if you are in a pinch, you could always take the roll pins out and install the one you have. Some cars don't even have a guide pin for their connections.
mk378 on Mon November 07, 2011 6:51 PM User is offline
I was thinking about suggesting just taking the pins out too, but if you look closely the solid thing is under the center port on the wrong one instead of the side port like the old one. It seems designed for the opposite flow direction, which would not work.
Edited: Mon November 07, 2011 at 6:54 PM by mk378
Cussboy on Tue November 08, 2011 2:26 PM User is offline
That's what I think too - get the right part.
