A/C issue
Lowcountrydave on Wed September 28, 2011 11:05 PM User is offline
Year: 2002
Make: Honda
Model: Accord EX
Engine Size: 2.3
Refrigerant Type: R134A
Ambient Temp: 85
Pressure Low: 43
Pressure High: 45
Hi,
My a/c use to work great up until about 6 months ago. I thought it had a slow leak. When I added a can of freon it would start working aginn. Now it has completely stopped cooling. Compressor still cuts on when the a/c button is turned on. Idle raises but doesn't seem to really put a load on the engine. I was thinking with the above pressures that the compressor has gone bad. But I sure could use some help figuring it out.
Thanks for any help you can provide.
Dave
mk378 on Thu September 29, 2011 8:47 AM User is offline
Only 40 psi it's almost completely empty. There is a major leak that needs to be found and repaired. Compressor performance can be hard to interpret without knowing there's a full charge.
Edited: Thu September 29, 2011 at 8:48 AM by mk378
