Gaskets for 10pa20c Denso
joeld on Tue August 16, 2011 10:14 PM User is offlineView users profile
Year: 1989
Make: Chev
Model: Corvette
Engine Size: 5.7
Refrigerant Type: R12
I'm trying to get a list together to order the #21-34629 shaft seal; #CP3010 O-ring kit; and #21-24688 O-ring kit for body of compressor.
My question is: I do not see the larger round gasket that goes lays on the Discharge Reed Valve. There is one on each end of the compressor. The Factory Manual says this gasket is non-reuseable.
Am I missing something here? Or does this gasket come in the #21-24688 kit?
The numbers on the compressor 10PA20-C
Thanks for any help
Joel
TRB on Wed August 17, 2011 1:02 AM User is offlineView users profile
I'll see what I can find out in the morning.
joeld on Wed August 17, 2011 11:28 AM User is offlineView users profile
Thank you,
Joel
TRB on Wed August 17, 2011 1:55 PM User is offlineView users profile
I added an image to the item number.
joeld on Thu August 18, 2011 9:13 PM User is offlineView users profile
Thanks for the update. So, I assume the swash plate gaskets are not usually changed when re-sealing this type of compressor?
Just trying to be sure if I decide to re-seal that it'll be correct.
Joel
TRB on Fri August 19, 2011 12:53 AM User is offlineView users profile
Not the guy to ask that. I don't rebuild compressors.
