Frosty Line ..warm air
jimRizzino on Tue August 09, 2011 6:55 PM User is offlineView users profile
Year: 2002
Make: dodge
Model: durango
Engine Size: 4.7
my main line has about a 1/4 inch of frost on it but the air is blowing warm/hot..any idea what may be causing this? ( the compessor runs)
Thanks in advance,
jim
Edited: Wed August 10, 2011 at 5:56 AM by jimRizzino
HotInOkc on Wed August 17, 2011 9:59 AM User is offlineView users profile
If it's frosty (not an expert) it's coming back to the compressor cold from evap.
So it appears to be working. Check to see if the vent system is functioning properly. You should be getting cold air....
Perhaps a blockage or maybe a bad linkage in the vent system
mk378 on Wed August 17, 2011 8:19 PM User is offline
Frosting could indicate the evaporator is also frosted over. When that happens, air cannot flow through it and get cold. So you have a reduced flow of warm air. The system controls (on most American trucks, a cycling switch) may be malfunctioning and allowing the frost-up to occur. Such a system will cool great for a period of time then change to warm air at a reduced flow.
