Need help with the a/c
Stresst on Wed August 03, 2011 7:00 PM User is offline
Year: 2000
Make: Cadillac
Model: Escalade
Engine Size: 5.7
Refrigerant Type: R134
I have been having a/c issues since April. It started with a leaking manifold hose but since then I replaced EVERYTHING except the front evaporator. I mean everything some parts were replaced multiple times but thats a whole other story. I ordered guages which finally arrived so I figured let me see whats going on. One thing I noticed on the highway this morning my center vent temps fluctuate big times anywhere from 38-45 degrees. Doesnt matter speed thou it seems to blow cooler when im going under 40mph. In the past few weeks it would stay around 38-40 no matter the speed on the highway until I either hit traffic or got off the highway.
Started the truck, outside temp is 83 degrees with 70% humidity.
5 minutes at idle:
low 50, high 210 with 66.5 center vent temp.
10 minutes idle
low 50, high 230 with 63 center vent temp.
5 minutes @ 1500RPM
low 40, high 360 with 58 center vent temp.
7 minutes @ 1500RPM
low 33, high 265 with 53.5 center vent temp.
10 minutes @ 1500RPM
low 32, high 260 with 52.8 center vent temp.
12 minutes @ 1500RPM
low 35, high 320 with 54.5 center vent temp
I recently replaced the fan clutch with a sever duty hayden, I added both a 9 and 14" electric fans on the condenser. But im still not happy. Any suggestions.
2000 Cadillac Escalade w/rear air
JJM on Wed August 03, 2011 10:23 PM User is offline
Important question: Where were the parts sourced from?
Sounds like an airflow issue, since the vehicle seems to cool well while moving. What happens to the vent temps and pressures if you water down the condenser?
When the system was opened for subsequent parts replacement, was more oil added? How long was the system vacuumed?
Joe
Stresst on Thu August 04, 2011 7:39 PM User is offline
Joe
Thanks for the reply. As far as the parts go they were purchased all over. The rear evap and expansion valve are both Delphi along with the accumulator, the manifold hose is a no-name, the compressor is GPD (being I had to send back two defective Delphi unuts), the hoses/lines that run front to rear are from Parker. The only part thats in question IMO is the condenser which is by Vista-Pro but its been the best compared the last 2 new ones. I added two electric fans which dont do much but when I spray water on the condenser the temp drops like a rock.
Angelo
BTW : I know oil was added by the second shop who replaced the 2 compressors. Actually when he opened the rear box the rear lines pissing oil for several minutes. Had to be 3 -5 ozs came out. As far as vacuuming it was NOT done the last few times its been open. I know know but it wasnt done.
I just purchased a Santech variable orifice made for 100+ temps, a new Delphi accumulator, and Enviro-Safe Advanced hydrocarbon freon. Im assuming my condenser is not adequate and if I have to replace I need to determine this now. This will be the last time the system will be open. Friggen ridculous 3 months and sub-par air!
Edited: Thu August 04, 2011 at 7:52 PM by Stresst
mk378 on Thu August 04, 2011 9:07 PM User is offline
You have air in the lines that's a big reason why performance is poor and pressure high. Evacuate and charge properly. Also fan clutch seems to be weak. Stay away from variable orifices and HC refrigerant.
Stresst on Thu August 04, 2011 9:25 PM User is offline
What makes you state to stay away from variable orifices and HC freon? ( This is all new to me)
Stresst on Thu August 04, 2011 9:28 PM User is offline
And as far as the fan clutch I recently replaced my stock unit with a new severe duty unit from Hayden, turns out it was bad out of the box. Upon accelerating it would immediately slow down nevermind temp went up about 10 degrees. So I replaced it with a new one which seams to be fine. But maybe im wrong. Im no expert but if I had to guess I would say the clutch is fine rather the condenser ( this is the 3rd new one in 3 months) is weak. Again I dont really know. I appreciate any help!
Edited: Thu August 04, 2011 at 9:38 PM by Stresst
JJM on Thu August 04, 2011 11:53 PM User is offline
First, the system was designed to use R-134a. Second, there is no reason to use a HC refrigerant when R-134a is legal, plentiful, and relatively inexpensive. Third, HC refrigerants can go boom.
What kind of HC refrigerant were you considering anyway? They all have different characteristics. I see no reason why the system needs to be re-engineered.
It sounds like your system is just one big hacked up mess. Is the condenser plumbed properly? Where was the OT installed?
Best plan of action would be as follows:
- Replace the compressor
- Replace the condenser
- Replace the accumulator
- Replace the OT (no variable orifice)
- Replace the rear TXV
- Replace any hoses with mufflers
- Thoroughly flush and dry the front evaporator
- Thoroughly flush and dry the rear evaporator
- Thoroughly flush and dry any remaining lines
- Replace o-rings at every fitting
- Add 11 oz of PAG 46 oil
- Pull a deep vacuum on the system for several hours or at least down to 600-700 microns. The longer the better. This an extremely important step that appears to have been skipped throughout.
- Charge system with 48 oz R-134a
All parts above should be brand new OEM parts, or parts from ACKits.com, otherwise you'll end up spinning your wheels. If you don't start with an operating room clean system, you're going to end up with repeat failures.
Joe
Stresst on Fri August 05, 2011 1:40 AM User is offline
I recently found out the condenser was plumbed incorrectly so we got that staightened out. The orifice is near the Y-pipe where it belongs. Like I said in my original post EVERYTHING is new except the front evaporator. I was thinking of Enviro-safe Advanced/Industrial R134 replacement. I understand about trying to redesigning the system but when your in for over 3K and the a/c is less then desireable im looking outside the box.
Im curious as to where you came up with 48 oz of R134?? Capacity I think maybe an issue........Alldata & Chilton both state 2.75lbs, while Napa and tech choice parts list 4lbs, I seen another chart that says 3.5lbs so I really dont know what is the actual capacity.
Edited: Fri August 05, 2011 at 1:57 AM by Stresst
Jase007 on Fri August 05, 2011 2:55 PM User is offline
Stresst:
I've read your threads & posts on the different AC / truck forums about your truck and I know you purchased a set of gauges to do some testing.
You seem to be chasing your tail as you have mentioned several times how much $$ you have put into getting cold air but also acknowledge that the system has been opened, parts replaced, oil added or not added and then no vacuum drawn (on a system with air in it?) before charging again ... you can't do this (pay someone to ) and expect results.
You have mentioned what a few shops have done or attempted to do and you don't seem happy.
I would cut my losses and start at the beginning as mentioned above.
Get educated on auto AC systems, get the basic tools needed (vac pump and gauges, let shop recover and flush) and do it yourself.
1st you need this:
Read and reread then read again first 5 chapters.
Perform the tests as described in the manual. (gauges)
Then I'd follow everyone's advice on how to:
1. properly evacuate
2. breakdown and flush
3. replace components
4. reassemble and add oil
5. pressure test
6. vacuum and test
7. ... and finally charge.
Good luck.
Jason
1999 GMC K1500 Suburban SLT
5.7L Vortec with C69 Rear Aux Opt,
JJM on Fri August 05, 2011 8:45 PM User is offline
Part of the problem seems to be repeat failures, and that's easy to see why with improper or no existent flushing procedures, lack of pulling a vacuum, which increases the probability of moisture in the system, and more oil than Saudi Arabia. The system needs to be operating room clean, with all correct parts, brand new.
Are you sure you got the right compressor in this thing? In 2000, GM used 3 different compressors for this platform:
- Delphi HU6: 6 cylinder, used only for the pickups.
- Denso 10S17: 10 cylinder, front air only (GM RPO C60)
- Denso 10S20: 10 cylinder, front and rear air (GM RPO C69)
The fact that you mentioned you had to bad Delphi units leads me to believe you have the wrong compressor for rear air; you need the Denso 10S20 which has quite a bit more displacement than the Delphi HU6. And of course, different displacement means different refrigerant and oil levels.
What orifice tube are you using? A lot of folks automatically dump the GM white 0.072", but I think this vehicle needs the GM yellow 0.062" instead.
Jase007 is also giving you very good advice... you're not getting this stuff done right and spending a lot money needlessly. Do it right, and you'll only be doing it once.
Joe
Stresst on Sat August 06, 2011 12:31 AM User is offline
Joe
I actually havent had any failures that required a flush (unless I dont understand the term).......As fas the orifice tube goes yes its the yellow one. Rite now I actually have one out of a ford (blue/double o-ring) in there and its been the best since we started. In regards to the compressor the Delphi's were the same exact one that was in there from factory but but when we installed the second one and it was no good I purchased a GPD from a local auto parts store. As far as doing it rite I tried! This wasnt something I tried to do on my own in my back yard to save a few bucks so please dont think that. Did the original guy specialize in a/c's? No but he does a/c work like no tomorrow. Im not sticking up for him as he plumbed the condenser backwards and cost me a boat load of money!
My problem is I cannot find someone who specializes in this stuff here in NYC! I know its hard to believe but I cannot.
Im not about to toss my compressor, condenser, rear evaporator and start over its just not gonna happen especially when I dont know the problem.
Angelo
Edited: Sat August 06, 2011 at 12:57 AM by Stresst
TRB on Sat August 06, 2011 1:00 AM User is offlineView users profile
My suggestion is to purchase the Alldata or Mitchell subscription for this vehicle. I doubt anyone is going to come up with a sentence or two to fix your issue. You have a thread here and another Bulletin board. Bottom line is you need to get back to the OEM setup. Proper oil amount, refrigerant amount and OT. if you willing to do that we can provide some guidance. If not, I can't come up with the magic answer. Scan tool may be needed to read the codes you might be getting also.
What help has your supplier provided with these issues?
Subscription Link
Edited: Sat August 06, 2011 at 1:10 AM by TRB
bohica2xo on Sat August 06, 2011 1:20 AM User is offline
Originally posted by: Stresst
(cue boxing announcer voice)
Aaaaand we have a contender from NY! So far the oil overcharge record is about 19 ounces in a dual evaporator suburban, but it looks like Angelo may be gaining on Tom!
Pull those evaporators & drain them! Drain that condensor! Drill a hole in the accumulator & fill those measuring cups! Angelo that title may be yours!
(sarcasm ends here)
You need to flush that system. Every component individually. Both evaporators, the condensor & all of the hard lines need to be flushed back to bare metal. Zero oil. None. Nada. Zip. Clean enough to make paint stick.
Throw the accumulator in the trash. Blow all of the oil you possibly can out of the flexible lines. Drain the compressor.
evacuate the system to less than 1000 microns, or it will never cool right.
B.
TRB on Sat August 06, 2011 1:24 AM User is offlineView users profile
Originally posted by: bohica2xo
(sarcasm ends here)
B.
Short hand- Get the vehicle back to OEM specifications. Personally I would toss those extra fans also.
Stresst on Sat August 06, 2011 2:57 PM User is offline
I already subscribed to Alldata which has taught me alot. My concern is I thought we had this problem in the bag when the second shop straightened out the plumbing on the condenser. Usually (if any) there is no more then one EFF up. But that doesnt seem the case. The question is what else could they have screwed up???
My next free minute im going to open it back up and put the correct orifice back in it and see what happens. As far as the correct amount of refrigerant well thats debateable as sources list several differant amounts as I stated before. I never in my life seen anything like this mess!
The first shop was more then helpfull in trying to resolve this issue. On top of them working on the a/c numerous times since the truck was first repaired they did my inspection ($37.00), rewired my electric fan with a relay and interior switch, synthetic oil change, installed the fan clutch ALL FOR FREE. This is probably due to the fact that I handle all the fleet maintenance at my job and send them a ton of work. So it wasnt like that got over on purpose as they have too much to lose. JMHO. Text
Edited: Sat August 06, 2011 at 2:58 PM by Stresst
Stresst on Sat August 06, 2011 3:04 PM User is offline
(sarcasm ends here)
B.
Is flushing each component necessary? ( Just asking ) Or can I find a shop with a machine to flush the entire system out?? Are there shops that flush each part? (probably a ton of cash)
Once the system is "flushed" how do put the correct amount (11oz) of oil back?
TRB on Sat August 06, 2011 5:04 PM User is offlineView users profile
Hecat's tech paper should cover these questions. As for oil. Much debated question. I go 80 percent compressor 20 percent accumulator or evap.
http://www.autoacforum.com/attachments/FLUSHING%20TECHNICAL%20PAPER%20vs2.pdf
bohica2xo on Sat August 06, 2011 5:04 PM User is offline
Flushing is really just part of a quality repair. There are no shortcuts, every component gets flushed by itself. It is not possible to flush through an expansion device, so the rear TXV needs to come out. Same for the front evaporator. The only way to get the correct oil charge in is to get all of the old oil out first.
Once the system is clean and dry, the new oil charge is added to the compressor and what does not fit there can be dumped into the new accumulator. Once the refrigerant begins to circulate the oil spreads around immediately.
A good vacuum is necessary to remove all of the air from the system. Less than 1000 microns, and as low as 400 microns is an excellent vacuum level for an MVAC system.
Unfortunately a lot of otherwise decent mechanics think A/C is just something to throw parts at, and do not understand how much trouble too much oil can cause. An extra four ounces of oil is like a quart overfill on a transmission. They would not think of filling a cold power steering system right to the brim, but 3x the oil charge in an A/C system does not sound like a big deal to them.
Perhaps if you sit down and carefully explain the problem and what needs to be done to correct it to your fleet service company they can help you resolve it. Having a tech on staff that knows what he is doing with A/C can make a shop a lot of money. A "teachable moment" as they say, that you may be able to make work for both of you.
B.
Edited: Sat August 06, 2011 at 5:05 PM by bohica2xo
