Can you determine refrigerant level based on pressures?
Briandl79 on Tue August 02, 2011 1:54 PM User is offline
Can you determine refrigerant levels based on pressures alone? In other words if my readings are whatever normal would be, let's say 35/250, is that enough to know I have the proper amount of refrigerant? How accurate would that be considered? Is it accurate to say 4 ounces, or dead on accurate?
Is the only true way to get an accurate idea of refrigerant level an evacuation and recharge with weighed refrigerant?
Just a general question. TIA!
Cussboy on Tue August 02, 2011 2:15 PM User is offline
Yes.
This can be a good indicator of approximate charge level, as well as the condition of the system. But for answer: see above.
Edited: Tue August 02, 2011 at 2:15 PM by Cussboy
GM Tech on Tue August 02, 2011 2:33 PM User is offline
You must weigh "out" the charge to know refrig amount
