Year: 1989
Make: Cadillac
Model: Barritz
Engine Size: v8
Refrigerant Type: R12
The AC on my '89 Cadillac Eldorado was working great then I got the "Low A/C refrigerant, A/C compressor off", message. After calling around to see who still had R12 I found a place and took the car in. They said I had a small compressor leak and put in one can to see if it held. On my way home it worked great-nice cold air which in the heat of a Florida summer, is a necessity. Unfortunately it only lasted a day before I got the same message. Is there any type of "fix" or "stop leak" for an old compressor? If a new compressor is a necessity, what are your suggestions regarding replacing the compressor, conversion of the system from R12, etc etc? I love this classic with it's Rolls chrome grill but if this is one of those things that is going to cost a fortune, I may have to re-evaluate repairing it versus parting with it. Any advice or thoughts about it would be greatly appreciated.
There are kits available to re-seal your compressor-- they are on a popular auction site.
Because I reseal all H-6 compressors---for much less than a new one. the kit is like $12....You own a caddy, they all have that low refrigerant message capability- since mid 80's.....
And yes, caddy owners can afford new compressors-- just thought you were looking for an less expensive alternative.
$175.00 for a new import with clutch. Send me an email if interested. Please do not use and sealers in this vehicle or any other. Some will tell you how great they are. We have seen the other side of the story. Plugged systems that require many if not components to be replaced.
I am definitely looking for the least expensive alternative and appreciate your answers. As far as it being a Cadillac , remember we are talking a 1989 poor guys car; not a new car which would be my preferred route if I had the money. I'm just trying to get some A/C back into my old car and use it as long as it still runs great and looks good. I will definitely look for the kit . Can you give me anymore clues as to specifics of what i'm looking for; Is the fact that it is still using R-12 a factor? If I do decide to go the new compressor route, I'm not sure if the use of R-12 is an issue, if it should be converted, if that means i'll need new parts in addition to the compressor? Really appreciate your thoughts as to the least expensive way to get ac back in it. Thanks again.
Do not convert, the complicated electronic control system is specifically tuned to the properties of R-12 and it simply will not work with R-134a. You can buy new compressors set up for R-12 with mineral oil.
GM Tech- regarding your statement that you reseal all H-6 compressors for much less than a new one- is that something that an auto A/C repair place would typically offer as an alternative to replacing the compressor ?
No- they do not care about saving the customer money-- they will replace compressor- it is much easier for them...they don't have to learn how to do it- or apply the tools they learned in mechanics school....
I make more off a re-seal then a new compressor install.....I do the reseal and avoid compressor costs- and do it for about 1/3 the total amount of a new compressor install..and still make more on the job .
Dang GM tech, so the chances or finding another "you" here that will do a reseal are probably real slim then. Atleast now that I know it's a possibility, I can atleast ask about it. Thanks again.
Indeed GM Tech is one of kind. I'd let him work on my vehicles any day... any I'm a picky PITA.
Joe
Thanks mk378 for your recommendation not to convert-I did read that about the electronic interfering somewhere else so I wanted to confirm it since a few places have suggested doing it. I just have to hope that if/when I can get the AC running again that I can continue to find the R-12.
JJM - wouldn't it be great if GM Tech could be cloned. It would be nice to find an A/C guy around here that would be willing to figure out how to save the customer a few bucks and still profit himself on the repair. The a/c guys around here, so far, have offered only one option- a new compressor with a lot of billable hours and when I mention the reseal I get a blank look and a negative nod.
Tim:
I've seen you mention this in several emails: "$XXX for a new import with clutch. "... Do you have a different source now? (See my messages posted on another thread).. I have a decisionn to make today on what I have to do to get my daughters's car back running again...
Thanks!
True Shade Tree
Edited: Mon August 08, 2011 at 8:58 AM by MHardee
