I guess they expect this one to blow up...
chris142 on Thu July 21, 2011 10:31 PM User is offline
Year: 06
Make: chev
Model: impala SS
Engine Size: 5.3L
Had one of these in my shop this week. Only had 55k and the compressor was rattling. GM is using an expansion block on this car but also has a filter that resembles an orifice tube right after the condenser output.
Filter was plugged so it got a major AC job.
A tip incase anybody has to replace a compressor on one of these. Remove the upper motor mount where it bolts to the core support. With the car on a lift. Put a jack under the front of the X-Member. Remove the 2 front X-Member bolts and loosen the 2 rear X-Member bolts. Lift the car up and the engine and trans will lower enough to get to the upper compressor nut and stud.
I don't think that you can get the compressor out any other way. I sure couldn't. Oh and have fun with the belt tensioner from hell.
JJM on Fri July 22, 2011 12:13 AM User is offline
Lovely... so they put the filter AFTER the condenser to ensure the condenser gets trashed. Why bother with the filter then?
A car that's just 5 years old needs nearly a total system replacement. Nice.
More reasons GM should have been allowed to fail.
Joe
bohica2xo on Fri July 22, 2011 2:25 AM User is offline
Makes sense, in a Genital Motors kinda way.
Place a secondary filter in the system - the condensor is the primary filter. This saves a 21 hour job to replace the evaporator, and the 5 comebacks for customer complaints of squeaks & rattles.
Obviously the system worked as long as it needed to - an '06 was shortly before the 100k warranty cars, would have been a 5/50 car. That filter was cheap insurance for the 10% that did not make it past warranty.
Thanks for the heads up on the compressor Chris.
B.
mhamilton on Fri July 22, 2011 12:13 PM User is offlineView users profile
They put the filter on the condenser outlet? Hmmm... I just found out a few weeks ago that most GM cars the past ~5 years or so went back to a TXV and they had a filter in the liquid line. Thought they finally went back to a high quality ac system. At least it's a step up from the ccot systems.
TRB on Fri July 22, 2011 4:05 PM User is offlineView users profile
I personally don't; think in line filters hold up well in the discharge line.
