Year: 1983
Make: toyota
Model: celica
Engine Size: 22r
Refrigerant Type: r12 to134a
Ambient Temp: 92
Pressure Low: 75
Pressure High: 180
hello there,my name is paul I have been to your fine establishment and purchased shaft seals twice. The compressor is a 10p15c,three times this has happened to me,I install the shaft seal so very carefully, put back on car evacuate[I can tell when it is down by shutting valve to the pump and what the gauges say]then leave it sit for an hour and no change on gauges,already added oil with comp. on the bench.Break vac.with gas[134a]start car add gas until suction press.hangs about 35 to 38 with car at 2000 rpm,s. a/c works very well for any where from 3 or4 days to 3 weeks is the longest run I have had.When I put gauges on always has high suction press.and when I remove comp.s[like I said 3 times 3 comp.s]it is like they dont pump any longer.This last time I bought the3rd comp.and it didnt pump after just installing the seal.So I tore it back down and totally cleaned up all the valve plates[seemed to have some aluminum corrosion on the valve plate] and all the valves,I used the best parts from all 3,installed vac.,charged ran about a week and right back to high suct. press lower tha normal disch. press.I have extensive ref. experience with large industrial centrifical chillers,even converting a 2500 ton machine to 134a,but I just dont get this little toyota, Your wisdom will be greatly appreciated.
Replace the compressor with a brand new 10pc15c instead of pulling parts from a bunch of other compressors and be done with it... unless this is what you enjoy doing.
Joe
Well I am truly sorry,for bothering you,but if I thought that the same thing would not happen to a brand new one I would probably buy one,but I believe that I was or am doing something wrong and thought that maybe you guys could tell me something before I went and ruined a new one.BUT apparently you dont know any more than I do.But some where there has to be some one that could converse halfway intelligently with me about this.
WOW.
3 compressors and we're the issue. No need for a pissing match if you don't; value the suggestions of the forum members. Good luck on your project.
Well, you might be right that I don't know anything more than you, but I've never been without working air conditioning on any vehicle I've ever owned - including a vehicle I currently own that's the almost the same age (1984) as yours. But if you want to spent a summer of record heat recovering, removing, disassembling, reassembling (with junk parts), reinstalling, evacuating, charging and still not having air conditioning, then by all means enjoy the summer heat! Gotta admire your persistence though...
Joe
