Year: 94
Make: ford
Model: ranger
Engine Size: 4.0
Ambient Temp: 75
Pressure Low: 30
Pressure High: 300+
ok just a little back ground i bought the truck and the compressor was bad so i went ahead and replaced the compressor, air dryer , orifice tube, and condenser it was full of junk i also flushed the system ....my problem is the high side pressure goes above 300psi and the low is around 30 aout side temp was about 75deg someone please help me im at my wits end
That 6mm Piccolo condensor does nor flush well - or easily. You say it was "full of junk". More than likely it has several partial blockages.
Of course you need to have the fan shroud & all air dams in place, as well as a properly functioning fan assembly. You will need to replace that condensor, and the orifice tube.
B.
Sorry, misunderstood your post.
If that is with a new condensor in the system, you could have either way too much oil in the system or a lot of air.
How long did it hold vacuum before charging?
How much oil is in the system?
B.
what do the pressures say when you mist the condenser with a water hose?
The high side service port is located on the DISCHARGE line of this vehicle. Elevated pressures at this point normally indicate a restriction in the condenser. How much lube was added to the condenser. Also was the condenser replaced as part of the initial repair or was it added later. From the post, it appears that an attempt to flush the condenser was part of the repair, yet a later statement indicates that the condenser was replaced.
Check the inlet and outlet temps of the condenser. Look for a temp drop app 24-28 degrees at idle.
Was the discharge/suction hose assembly replaced or flushed? This system utilizes a hose assembly with a muffler. This is a great place for debris to accumulate and then be moved into the condenser at start up.
