evaporator water inside Jeep
fonebone on Sat July 09, 2011 6:34 PM User is offline
Year: 1996
Make: Jeep
Model: Cherokee
Refrigerant Type: 134
Ambient Temp: na
Pressure Low: na
Pressure High: na
A friends jeep is getting wet on the pass. side floor, evaporator drain plugged. I fixed one last year (could NOT see the hose through the frame!). Inside that vehicle, the plenum chamber tapered down to a Vee where the hose went down through the frame, so we drilled a half inch hole at the bottom of this "V" and, using a bent wire, pulled a ton of rotten leaves and junk out through the hole till it was clean. Problem is, THIS vehicle does not have this design. What's the hot setup to stop this water coming onto the floor? Thanks for any help!
Edited: Sun July 10, 2011 at 6:47 PM by fonebone
