Year: 2003
Make: Pontiac
Model: Montana
Engine Size: 3.4
Country of Origin: France
Hi
All apologies for my bad english.
Alone un France with my 03' Venture A/C went out suddently.
The facts :
My mechanic change :
- new AC Delco compressor (comes with clutch)
- new pressure sensor
- new R134a
Tests done :
- pressure : OK
- all fuses : OK.
- relay OK. (A/C clutch relay is the same as the horn relay, I swapped them around (with the van off) and tried again : A/C clutch doesnt works but the horn does.)
- fan 1, fan2 and fan common relay : ok.
- clutch test : I hear a click sound of clutch when I hot wire the contacts of the clutch relay circuit (87 & 30). The AC works, it blows cold.
- BUT no signal comes from the inside command : no signal (85 -> 86).
I own the Haynes with wiring diagram but I dont have any ideas to look for.
Thank you for your help
JAS
problem is upstream from relay---obviously.....so measure return voltage on pressure transducer 3 wire connector--one wire should be 5 volt, one should be ground, and one should be 1 volt or less (static pressure considered).......
Control head okay? a/c button lit? nothing flashing upon engine start-up?
Where is it located ?
Okay I will measure it after the #1 answer ;-)
>Control head okay?
Duno
>a/c button lit?
Yes
No
Thank you.
JAS
