No power to a/c clutch
LUCKYSTATTOOS on Wed June 22, 2011 4:56 PM User is offline
Year: 2000
Make: ford
Model: excursion
Engine Size: 6.8
Refrigerant Type: r134
I have no power at the a/c clutch. I do have power at both the high and low switches. I have jumped the low pressure switch and still nothing at the clutch. All fuses are good as also the relay. I traced the clutch wire all the way to the a/c diode and that circuit is good, where it goes from the a/c diode I do not know. Any ideas would be greatly appreciated.
Sheldon
bromodragonfly on Wed June 22, 2011 5:56 PM User is offlineView users profile
Hope this may be useful:
Wide Open Throttle relay will cut the AC out when the engine requires maximum throttle (WAC). If this relay is defective, it can prevent the clutch from getting power.
Edited: Wed June 22, 2011 at 6:01 PM by bromodragonfly
LUCKYSTATTOOS on Wed June 22, 2011 6:17 PM User is offline
this is great thank you....Where is the WOT relay located. It does not show in manual.
bromodragonfly on Wed June 22, 2011 6:32 PM User is offlineView users profile
Just by googling, it looks like it is either in the engine compartment fuse box, or in the 'battery junction box, under the hood, on driver's side near the firewall'
another says: "UNDER the power Distribution panel on Rt side fender under hood." but this is in reference to a Ranger. Sorry I can't give you a definite answer
Edited: Wed June 22, 2011 at 6:37 PM by bromodragonfly
