AC inline filter
TH0R on Mon June 20, 2011 11:03 PM User is offline
Year: 1995
Make: Chevrolet
Model: Impala SS
Engine Size: 5.7
Pressure Low: Empty
Pressure High: Empty
The orifice valve is basically part of the condenser on the out line in my 95 Impala SS. Where am I suppose to put an inline filter if it is suppose to be between the condenser and orifice valve? Is there another location I can put it? Has anyone else had this problem on a Chevy?
GM Tech on Mon June 20, 2011 11:09 PM User is offline
I don't use them...
bromodragonfly on Mon June 20, 2011 11:21 PM User is offlineView users profile
There's no need for an aftermarket liquid line drier. Do you not have a suction filter of any kind between the evaporator and compressor?
HECAT on Tue June 21, 2011 10:24 AM User is offline
The filter is designed to go in the liquid line between the condenser and the orifice. In this case you do not have that line to tap into.
