I have been using my Mastercool 1.5CFM 90061 vacuum pump for years without problems. Always kept the oil to the full line and changed the oil after each use. But when I used it today, it pulls a good vacuum but apparently overheats after an hour or so and shuts down. Any ideas on what I need to do?
First off an hour on the pump is plenty of enough time to do what is needed. If you are concerned about the operation. Call Mastercool on Monday.
Mastercool.
