Year: 95
Make: Jeep
Model: Wrangelr
Engine Size: 2.5L
I installed your 8017 kit into my 95 wrangler in 2004 and love it. Still working great and producing cold air. However, I never tied it into the PCM for idle control which is why I am writing. I am wanting to run a wire down stream of the low pressure switch to the PCM AC connector (C213) similar to how the factory air is setup (AC Request Signal & jump the AC Signal - 28 / 27). Problem is, I can no longer find my installation instructions &/or wiring diagram (not sure if this was originally included) for your kit. Can you post the information so I know what wire to tap into for the low pressure switch?
foxtwo
We have never tied into the computer on this vehicle. Not needed in our opinion.
