Year: 2003
Make: Chevrolet
Model: Tahoe
Engine Size: 5.3
Ok i replaced the compressor and others parts last year because it was making a horrible rattling noise, well the noise returned but the a/c still worked fine, well yesterday i noticed that my a/c stopped blowing cold so I figured the belt had broken, well when I looked under my truck i noticed the belt was fine but the a/c tensioner was broken, appears that the spring inside of it broke. Anyways I spun the clutch on my a/c and it seemed to move freely like it's supposed to so I installed a new tensioner and belt last night. When I turned the truck on to see how the belt was tracking and everything looked fine. Well I turned on the a/c and it was working again so I decided to look at the belt again with the a/c engaged and I noticed that the tensioner was moving a good bit. So is this normal operation for the belt tensioner for the a/c to bounce around and also I turned on the a/c this morning on the way to work and the rattle was still there but not for long like before so I just turned the a/c back off. Anyone got any advice?
A forum search can provide this video I took awhile back.
Belt tensioner rattle
Did you thoroughly flush out the system with your last compressor and at least replace the accumulator? Did your last compressor seize? How did you deal with the condenser?
No, a dancing tensioner is not normal, your compressor is not providing a constant load on that belt, system may be pumping sludge for all you know or a piece of debris is hanging up a reed valve.
I flushed out all the lines and replaced everything else, and no my last compressor did not seize, I still have it, I replaced it because of the damn noise but it didnt stop so im completely lost on this. The compressor not putting a constant load sounds about right to me because I noticed before the tensioner broke that the colder air would cycle in and out if you understand what I mean by that, it would blow cool then cold and keep alternating like that.
Least your system has a separate belt for the compressor to out rule other items in the belt train. So that just leaves the harmonic balance, tensioner, belt, and the compressor.
Some of these harmonic balances have that rubber sleeve that rots away.
Or the belt can have a flat spot in it. Just a couple of more things to check.
