Year: 1991
Make: Chevy
Model: Corvette ZR-1
I realized today that when I replaced my evaporator, I inadvertently installed one for a 94-95 model, which used R-134a. The core physically fit into the housing, but required a tiny modification to the plastic. I figured it was just one of those aftermarket parts issues, but I now realize there's a separate part for 90-93, which used R12. Probably a stupid question, but is there likely to be any problem with system performance in this case?
Edited: Tue May 24, 2011 at 10:19 PM by vettemed
All r-12 evaps, lines, hoses, and condensers used English threads
All 134a evaps, lines, hoses, and condensers use Metric threads.
Changeover for Corvette was 94 MY.
Metric threaded connections have a line cut in the nut or in the base of thread
So do you foresee an issue?
OK, thanks. This aftermarket evap must have been an R12, but used the later design, as the threads were without question the correct type.
