Need a cluch coil
medium1 on Fri May 13, 2011 8:39 PM User is offline
Year: 2000
Make: Saturn
Model: type s
Engine Size: 1.9
Refrigerant Type: 134
Lost the third cluch coil open in 3 years. I need to buy a used compressor to get the cluch ciol and wanted to know if anyone knew which cars used the same compressor and clutch coil? Its a 2000 Saturn type S it has a 2 pin plug connector but uses only 1 pin and wire. It's hard to find a cheap compressor for that specific car when I only need the coil. I have replaced it twice before and it is an easy job.
TRB on Fri May 13, 2011 10:14 PM User is offlineView users profile
1999SaturnSLL4 1.9L 116cid
2000SaturnSLL4 1.9L 116cid
2001SaturnSLL4 1.9L 116cid
2002SaturnSLL4 1.9L 116cid
1999SaturnSW1L4 1.9L 116cid
1999SaturnSW2L4 1.9L 116cid
2000SaturnSW2L4 1.9L 116cid
2001SaturnSW2L4 1.9L 116cid
1999SaturnSC1L4 1.9L 116cid
1999SaturnSC2L4 1.9L 116cid
2000SaturnSC1L4 1.9L 116cid
2000SaturnSC2L4 1.9L 116cid
2001SaturnSC1L4 1.9L 116cid
2001SaturnSC2L4 1.9L 116cid
2002SaturnSC1L4 1.9L 116cid
2002SaturnSC2L4 1.9L 116cid
NickD on Sun May 15, 2011 9:15 AM User is offline
If your clutch gap is a tad too wide, hub will overheat, and the first thing to fry would be your clutch coil. Your compressor may be just be seized enough to work, but overloading your clutch. Here the clutch and coil are the victims and not the culprit. Would find exactly what that culprit is.
Could buy clutch coils in OEM quantity. A lot cheaper if you buy a thousand.
