SD709 ok for 134a?
mjlinder on Wed February 02, 2011 4:09 PM User is offlineView users profile
Year: 1991
Make: Jeep
Model: Cherokee
Engine Size: 4.0
Starting on the A/C system on my Jeep XJ. The current SD709 is shot. If I go with another 709 will it work ok with 134a? If not, it looks like the SD7H15 has the same mounting configuration. Or is there something else better that I should be looking at? I live in Phoenix so good A/C is a must!
Thanks!
TRB on Wed February 02, 2011 5:15 PM User is offlineView users profile
SD7H15 is the better option. Main issue is going to be the condenser not removing the extra heat load of the R134a refrigerant. I would consider a condenser up grade if converting this vehicle.
mjlinder on Thu February 03, 2011 3:42 PM User is offlineView users profile
Thanks! Everything from the firewall forward is getting replaced, including a parallel flow condenser from AMA.
TRB on Thu February 03, 2011 3:51 PM User is offlineView users profile
Thanks for the support.
