Year: 1996
Make: Ford
Model: Explorer
Engine Size: 5.0
Refrigerant Type: R-134a
I had to have my A/C evacuated at a shop to remove the evaporator so that I could replace the heater core in our Explorer. The A/C was working fine before the heater repair. I didn't lose any oil in the process and the ports were covered when the evaporator was out (about a week). I've got everything back together now.
I started to do a recharge last night, but realized after putting in about 6-8 oz of R-134a that
1. I need to jumper the low side pressure switch to get the compressor to come on.
2. I really should pull a vacuum to dry out the system.
I can rent a vacuum and manifold guage kit at the local Autozone. My question is whether I can pull a vacuum with the partial charge in the system?
Then, once I have the system pumped down and dried out, I can add the rest of the specified charge (1 lb 14 oz total).
Thanks!
You must reclaim any refrigerant in the system before pulling a vacuum.
I thought so.
Thanks.
you should change the drier/accumulator also
You should really put the jumper wire back where you got it.
Or, you can jumper the low pressure switch. Make sure you get that compressor spinning right away, in vacuum. Rev the engine up to about 1800 rpm for good measure. Now, fumble around getting the charging lines on, & the can tapped. This gives the compressor a chance to get good & warm. Now that the compressor is hot, with no refrigerant mass flowing through it for cooling & no oil returning from the refrigerant loop you can begin charging. Charge as a gas through the low side, and take your time. Refrigerant gasses are great degreasers, so this will help wash away any lubrication left in the compressor. By now you should be able to warm dinner on that compressor.
Eventually, you will either get it charged, or the seized compressor will snap the drive belt. If you get the charge in, you can wonder why the A/C never works as good as it did before the re-charge. With some scuffing damage & huge clearances from running without oil or cooling (thanks to the jumper wire) your compressor just can't match the old performance levels.
Jumper wires sell compressors.
