Year: 2003
Make: KIA
Model: OPtama
Engine Size: 3.7
Refrigerant Type: 124
Working on a 2003 kia and need to know what compressor this is and does anyone know if a shaft seal is available?
The compressor Has HCC on the label and a sticker on the body that says A6V.
any help?
Jerry Delaney
The forum sponsor - ACKits.com - has your model listed but not the engine size you specify.
I don't know if they're there on Saturday, but you might give them a call - 602-233-0090 (after the sun comes up it's still early in AZ )
Good Luck 2 ya,
Timmy
Must be a typo as no one lists a 3.7.
Compressor Type HALLA
Part Description COMP HS18 PV6 127mm 01-06 KIA OPTIMA 2.5/2.7L
Clutch Diameter 127mm
Oil Type PAG 46
Oil Capacity Oz 5.5
Grooves 6
Voltage 12
