i need to install dye
adglascoe on Sat October 02, 2010 2:32 PM User is offline
Year: 2000
Make: ford
Model: excursion
Engine Size: 10
I need to add dye to my ac i need to know how much to add and if i can buy it at the local parts store
Chick on Sat October 02, 2010 7:52 PM User is offlineView users profile
Your truck should have it from the factory.. I'm not 100% sure, but most do today, anyway, if you're adding to an empty system (without dye in it) you can add 1/8 to1/4 ounce, no more.. If you're changing a part, just use the correct amount of PAG 46 oil with Dye in the oil same if you've flushed the system...
mk378 on Sun October 03, 2010 7:19 PM User is offline
If it has factory dye, you will see it in the service ports.
