I am seeking an electric - not vacuum - 4 port heater valve. Preferably 5/8" for all ports.
I've found information on a Thermotion valve - PN 354-69494 but have found no vendor selling it.
I've also found one on eBay, part of a conversion kit, but have not been able to identify it.
Any help you can offer as to original application, part numbers, purchasing information is appreciated.
Larry
Edited: Wed September 08, 2010 at 1:45 AM by PANTERA2511
That valve you listed? They are OEM suppliers, they might be able to tell you what car that wound up on. Some of the other valves on that site I recognize - the 2 way vac units were used on a lot of fords. That valve is likely a stepper motor, since they call out a six pin plug for it.
There are some bypass valves in use on newer cars. The '03 to '05 Lincoln LS used an electric valve. '03 - '04 Cadillac CTS used a vacuum valve with a solenoid valve attached.
I use a vacuum unit, like the the AC Delco P/N 155536 It was used on G vans, and P vans from 1990 to 1996, as well as some chrysler products starting about 1988. They are cheap (less than 12 bucks) and reliable. Also available from local stock nationwide. A small solenoid valve makes them "electric".
B.
We have it available. Feel free to give me a call at 1-800-648-4475 to discuss pricing. I am assuming this is the part you are refering too.
Our part number is 3160027.
