evaporator (vent) fan stops running? I've a car that the vent fan quit, compressor cycles off/on due to thermo switch (I think). Pressures seem normal (175 hi, 40 lo). Can vent fan failure cause overpressure?
Thanks, Drake.
It is assumed you are speaking about the blower fan on the evaporator. If so, no,not normally will this result in excessive head (discharge) pressures. What could occur is that the system could pump liquid refrigerant into the compressor...and that will result in serious problems. The cycling is the result of the low pressure or evap temp sensor shutting down the compressor because the evap temp/pressure is falling below a certain range due to the lack of air flow and the super cooling of the evaporator.
that is how I test cycling switches in hot weather- unplug the blower motor
