Liquid line won't disconnect?
edhunter on Fri August 20, 2010 12:08 PM User is offline
Year: 2001
Make: Jeep
Model: Cherokee
Refrigerant Type: 134
I am trying to disconnect the liquid line from the condensor with a spring loaded tool. It will not release the spring. The other side was no problem. I will try PB blaster next. Is there a special trick to pop this off without killing my self
GM Tech on Fri August 20, 2010 12:52 PM User is offline
I usually give them 20 minutes-- if not loose by then, ,I cut them off--- corrosion is not your friend-- it has crawled in under the garter spring, and will not allow it to expand far enough to release---you may be there a couple of days trying to release it-- my time is worth the price of a new line-- so I cut them after giving it a good try....
edhunter on Fri August 20, 2010 1:21 PM User is offline
Ok, I will try a few more times
Edited: Fri August 20, 2010 at 1:31 PM by edhunter
