Year: 2000
Make: Chevrolet
Model: Silverado 1500
Engine Size: 5.3 L
Refrigerant Type: 134A
Hi, Could someone please tell me what the refrigerant capacity and appropriate high and low side pressures for the above vehicle would be at 80 degrees or so? Thanks, notsobrite
if you're using a Denso compressor; 29 oz of R134, pag 46 oil , 8 oz
if you're using the HT6 compressor; 32 oz R134, pag 150 oil, 8 oz
Compressor has 35 delphi on it. Can't easily see other numbers. Sticker says pickup 134a capacity is 1.8 lbs. Still would like to know appropriate high and low side pressures for the above vehicle would be at 80 degrees or so. thanks
Depending on humidity, low side says anywhere from 35-44psi and high side anywhere from 182-212psi.
Thanks for the help. Appreciate it very much. Terrific site
