Year: 2005
Make: Saturn
Model: Vue
Engine Size: 2.2
Ambient Temp: NA
Pressure Low: NA
Pressure High: NA
Nobody seems to have my drier in stock. so..........
I'm wondering if it's possible to flush out the drier to get rid of the oil then
Pull a vacuum on it while heating it up to drive out the water from the desiccant to 'recharge' it?
How hot, how much vacuum and how long?
thanks
Ed
SoCal
You would need inert gas and high temperature to remove water from most desiccants. And high temperatures would likely destroy the bag that holds the pellets, causing huge problems. Did you contact the board sponsor AMA? ACkits.com
Yep only vendor I see with one in stock is 3 times our normal price.
Is this the unit required.
That the one I list.
I dunno how much 3x the normal price is, but the drier for my RX-7 is difficult to find as well, and I found one company that will re-manufacture (cut open, replace desiccant, re-weld) your drier for around $100.
I'll check inventory tomorrow...see if it is available.
We once 'rebuilt' accumulators....back in the day.....cut them open...replaced the dessicants...did an upgrade....used larger dessicants than GM...rewelded and pressure tested. Need to test with refrigerant...not air.....contaminates the dessicant.......for a 'bunch' less than 100....but then gas was less than a dollar...cokes were about a quarter.....movies...yes, TRB they were in color but were a lot less than $10.00
Edited: Fri August 13, 2010 at 9:59 PM by iceman2555
Ed, this site usually doesn't permit references to other vendors, but might in this case. It looks like rockauto.com has it for just under $47. It's FOUR SEASONS Part # 83101, and the little picture looks just like the one above.
Once you scroll to your year, vehicle, etc., it's under "Heat & Air Conditioning, then under AC Receiver-Drier/accumulator.
Edited: Fri August 13, 2010 at 10:56 PM by Cussboy
vs $21.49 at ACkits..........
Plus shipping......... (so about $33 (ackits) vs $55 (rockauto))
If an online ordering system takes your order, there's some expectation that you'll get the part in a timely manner (or be notified right-away, and you personally don't have to bug them about the order)...........
Ed
SoCal
