Year: 95
Make: Olds
Model: 88 Royale
Engine Size: 3.8
Refrigerant Type: 134
I screwed up and didn't pull the switch out of the old compressor before turning it in.
I picked up a new one.
Now, I don't know which hole it goes in. There are two holes and I have a 50/50 chance to guess.
Using the Mastercool service manual, I figure the compressor is a Harrison HR-6 6-cylinder.
Page 218 fig. 16, shows the back side of the compressor. Is that the switch in the bottom right hole, under the discharge port?
Quality is never an accident it is always the result of intelligent effort.
I believe you can use either port. GMTech will probably know for sure.
They are both high side communication ports-- use either one....
Depends upon the type switch...is it a high pressure cut out...or is it set for the low side as protection. If memory serves me correctly, one switch is normally closed and one is normally open. The switch is normally a high side protection device, and in this case should be installed on the discharge side of the system.
Please supply the part number for your switch so that it can be validated to insure that the correct part number was supplied.
A 95 H car has an HD-6 compressor- definitely a high pressure cut-out switch-- no other switches were used in that model year compressor- mounted on the compressor....guaranteed--
Is not only one side machined out (internal port) anyway?
Some units have both ports machined. A metal cup is used to seal the non utilized port. GM uses two rear heads.....major difference is the 'clocking' of the manifold connection points.
I'll pull a 'head' tomorrow and check ...just to be sure.
Man this internet thing sure makes a man lazy. Thanks for the replies. I remember back when I used to have to remember how stuff came apart in order to get it back together. Now that I think about it, I will know for sure tomorrow when I set the compressor in place and see how the wires are routed. Discharge side was my guess.
I have another issue will start another thread.
This is a GM 'A' read head with both switch ports machined. It is more cost efficient to machine for both and then simply use a 'plug' for the non used location. Both ports are located in the discharge side of the unit. The 'B' head is basically the same.
Edited: Wed August 11, 2010 at 1:34 PM by iceman2555
