Year: 2005
Make: Saturn
Model: Vue
Engine Size: 2.2
Ambient Temp: NA
Pressure Low: NA
Pressure High: NA
The o-rings I've found so far are the rubber surrounded by metal.
When you look up the o-rings kits at ackits.com it shows part
CP3010 o-ring kit for 1989-2005 GM which is just plain rubber o-rings.
But there is also a kit
CP3016 kit for 2005 and prior GM sealing washer kit which looks like it has the metal/rubber o-rings
Which kit should I use, and is it really ok to replace the metal/rubber o-rings with just rubber?
thanks
Ed
SoCal
Both.
Sealing washer kit is for the compressor. The other kit is for all the other connections.
