Year: 1969
Make: Ford
Model: Mustang
Engine Size: 302
I have a 69 mustang with after market air on it. I had a condenser leak that is now fixed and need to replace the filter/drier.
The filter /drier is an ATCO 7-4102. I cant find it locally, I am looking for this drier or the correct cross reference to an equal one.
Thanks Tod
Personally can't find any cross that would be able to be used locally.
Does the dryer look like this:
Those are hose barbs under the yellow caps. If you have clamped hoses on the dryer this will fit. Otherwise we will need a pic of your dryer to match it up. There is no master catalog for aftermarket systems.
B.
Ford oem part # ATCO part #
C8OZ-19959-A .................................. 7-4102
I got this info from http://www.atcomail.com/2006Catalog/OEAtcoIntchg.pdf
Aftermarket to ATCO is here http://www.atcomail.com/2006Catalog/AftermarketApcoInterchg.pdf
Picture of Ford part
http://macsautoparts.com/mustang-air-conditioner-reciever-dryer-reproduction-of-original-for-factory-air-conditioner-c9zz-19959-a/camid/MUS/cp/MI0ILRS61000181/
http://www.trophymustang.com/196970-filter-dryer-p-3816.html
hope it helps
Edited: Sat July 31, 2010 at 4:19 PM by mb
This drier is available from various sources. Application is for 73-71 Ford, 72-68 Mercury. Ford # D2ZZ-19959-A,C80Z-19959-A,DODZ-19959-A.
Murray part number is 208368.
TRB, I checked your site....did not located it
Looks just like the ones used on the 65 and newer mustangs. Flair fitting where it sttaches to the condensor on the bottom?
todamay, if you would take the time to read my post......there is a part number listed for the darn thing. It is readily available from most auto parts jobbers. They may have to order, but should be in over nite...or second day for sure.
Sorry been away.....travelling once more....
I missed that one.....but glad you had it to offer....I shall search more diligently next time...promise.
That's OK ice. I have a few tricks I use to find things. Just like you have 2 sets of tooling!
