Year: 1968
Make: Olds
Model: Cutlass
Engine Size: 350
Refrigerant Type: R12
Hi All,
I am getting ready to overhaul the original A/C system on my 1968 Olds Cutlass Vista Cruiser.
I have a rebuilt compressor which I picked up at Autozone a while back. However, a lot of discussion that the rebuilds tend to be hit or miss in terms of longevity.
I see that FourSeasons offers a new, not rebuilt A6, which they list as part #58089 which I can pick up for about $400. The only potential glitch is that while this shows as a match for lots of late 60's, early 70's GM products, they do not show it as a match for the 1968 Cutlass. Instead, they show rebuild part #57092.
Is there any significant difference from one year to another? Do you anticipate that I would have any problems using the new one described? Would fittings and electrical connections remain the same?
Thanks.
Mike
differences are pulley sizes, connector locations, switch inserted in rear head-- other than that they are all the same...
I think the internals are different with the FS compared to the APCO.
Here are the differences of the two compressors you listed:
Four Seasons - 57092
Type: Compressor Reman /GM A6
Belt Type: Single Groove
Belt Width: 7/16"
Coil Clock: 2
Coil Type: Spade
Manifold Block w/ O-Rings
Mnt. Dist. To Groove1 Midpoint: 1.95"
Mount: Standard Threads
Pulley Dia.: 5.12"
Switch: Superheat
Four Seasons - 58089
Type: Compressor New /GM A6
Belt Width: 7/16"
Coil Clock: 2
Coil Type: Spade
Mnt. Dist. To Groove1 Midpoint: 2.00"
Pulley Dia. 5"
Switch: Superheat
So other than the pulley being just a touch smaller on the new one and being placed 0.05" closer to the radiator, they are pretty much the same on the outside.
The pulley size will only run the compressor 2.3% faster than spec. That and a new belt might be needed. I'd be more concerned with the .050" pulley offset. That can wear a belt pretty fast. Even throw it at high speed. You might be able to adjust the mounts a little and get that .050" back though.
Ken Kopsky
Custom Car Works
I was just looking at ACKits.com and see that they list a model 20-10405 which is also a new A6 unit. What are the specs on that? Perhaps it is an even closer fit?
Thanks. Bottom line is that I would like to order a new (not reman) compressor for my 1968 Olds Cutlass Vista Cruiser. Is there an appropriate unit available?
Thanks.
Mike
There are people out there that will put your shell on a new gut pump--so that you have your original part numbers and date codes showing for the compressor-- this is for those who are very particular to having the OEMparts on their classic cars...
Would you know what companies offer this service? Would swapping out the shell introduce some of the seal problems which seem to plague the rebuilt units? Thanks.
